Пие ми се МЕТАНОЛ!!!
- LordDigital
- СупраДжия
ДА не се стреската де ,ке уживея
Ма тва в да подцетя РАКЕТОВ да ме снабди със количество ,че скоро ча се присрастявам. Подробности по темата по-нататък
Re: Пие ми се МЕТАНОЛ!!!
Ah tozi drag ... laugh.gif , kakwo li drugo 6te ti se dopie!LordDigital написа:ДА не се стреската де ,ке уживея
Vnimavaj, 4e moje da e otrovno i za dvama vi!
Ti po-dobre go karaj na etanol za po-sigurno, a Suprata dali 6te izdurji na metanol???
Maj si se dopitval do srubskiq tuning, a?
Methanol, absolute , Acetone free.
Лорде, ще ти струва 38$ на галон(3.785л)+доставка.
Прочети МСДС-а и виж какво съм подчертал
1. Product Identification
MSDS Name: Methyl alcohol, reagent acs, 99.8% (gc)
Synonyms: Carbinol, methanol, methyl hydroxide, monohydroxymethane, pyroxylic spirit, wood alcohol, wood naptha, wood spirit.
2. Composition/Information on Ingredients
CAS# Chemical Name % EINECS#
67-56-1 Methyl Alcohol 99+% 200-659-6
Hazard Symbols: T F
Risk Phrases: 11 23/25
Top of Page
MSDS Index
3. Hazards Identification
EMERGENCY OVERVIEW
Appearance: APHA: 10 max. Flash Point: 12 deg C.
Warning! Flammable liquid. May cause skin irritation. May cause central nervous system depression. May be absorbed through the skin. May cause kidney damage. May cause respiratory and digestive tract irritation. May be fatal or cause blindness if swallowed. May cause fetal effects. Causes severe eye irritation and possible injury. Target Organs: Kidneys, central nervous system, eyes.
Potential Health Effects
Eye:
Produces irritation, characterized by a burning sensation, redness, tearing, inflammation, and possible corneal injury. Vapors may cause eye irritation. May cause painful sensitization to light.
Skin:
Ingestion:
May be fatal or cause blindness if swallowed. May cause irritation of the digestive tract. May cause kidney damage. May cause systemic
toxicity with acidosis. May cause central nervous system depression, characterized by excitement, followed by headache, dizziness,
drowsiness, and nausea. Advanced stages may cause collapse, unconsciousness, coma and possible death due to respiratory failure.
Inhalation:
May cause respiratory tract irritation. May cause visual impairment and possible permanent blindness. May cause effects similar to those
described for ingestion.
Chronic:
Prolonged or repeated skin contact may cause dermatitis. Chronic inhalation and ingestion may cause effects similar to those of acute
inhalation and ingestion.
Top of Page
MSDS Index
4. First Aid Measures
Eyes:
Flush eyes with plenty of water for at least 15 minutes, occasionally lifting the upper and lower lids. Get medical aid immediately.
Skin:
Get medical aid. Flush skin with plenty of soap and water for at least 15 minutes while removing contaminated clothing and shoes.
Ingestion:
If victim is conscious and alert, give 2-4 cupfuls of milk or water. Never give anything by mouth to an unconscious person. Get medical aid immediately. Induce vomiting by giving one teaspoon of Syrup of Ipecac.
Inhalation:
Remove from exposure to fresh air immediately. If not breathing, give artificial respiration. If breathing is difficult, give oxygen. Get medical aid.
Notes to Physician:
Effects may be delayed. Ethanol may inhibit metabolism.
Top of Page
MSDS Index
5. Fire Fighting Measures
General Information:
As in any fire, wear a self-contained breathing apparatus in pressure-demand, MSHA/NIOSH (approved or equivalent), and full protective gear. Vapors may form an explosive mixture with air. Vapors can travel to a source of ignition and flash back. Will burn if involved in a fire. Use water spray to keep fire-exposed containers cool. Flammable Liquid. Vapors may be heavier than air. They can spread along the ground and collect in low or confined areas. May be ignited by heat, sparks, and flame. Containers may explode when heated.
Extinguishing Media:
For small fires, use dry chemical, carbon dioxide, water spray or alcohol-resistant foam. Use water spray to cool fire-exposed containers. Water may be ineffective. For large fires, use dry chemical, carbon dioxide, alcohol-resistant foam, or water spray. Cool containers with flooding quantities of water until well after fire is out.
Autoignition Temperature: 455 deg C ( 851.00 deg F)
Flash Point: 12 deg C ( 53.60 deg F)
NFPA Rating: health-1; flammability-3; reactivity-0
Explosion Limits, Lower: 6.00 vol %
Upper: 31.00 vol %
Top of Page
MSDS Index
6. Accidental Release Measures
General Information: Use proper personal protective equipment as indicated in Section 8.
Spills/Leaks:
Absorb spill with inert material, (e.g., dry sand or earth), then place into a chemical waste container. Remove all sources of ignition. Provide ventilation. A vapor suppressing foam may be used to reduce vapors. Water spray may reduce vapor but may not prevent ignition in closed spaces.
Top of Page
MSDS Index
7. Handling and Storage
Handling:
Wash thoroughly after handling. Use only in a well ventilated area. Ground and bond containers when transferring material. Empty containers retain product residue, (liquid and/or vapor), and can be dangerous. Keep container tightly closed. Avoid contact with heat, sparks and flame. Avoid ingestion and inhalation. Do not ingest or inhale. Do not pressurize, cut, weld, braze, solder, drill, grind, or expose empty containers to heat, sparks or open flames.
Storage:
Keep away from heat, sparks, and flame. Keep away from sources of ignition. Store in a tightly closed container. Store in a cool, dry, well-ventilated area away from incompatible substances.
Top of Page
MSDS Index
8. Exposure Controls/Personal Protection
Engineering Controls:
Use adequate general or local exhaust ventilation to keep airborne concentrations below the permissible exposure limits.
Exposure Limits:
Chemical Name
ACGIH
NIOSH
OSHA - Final PELs
Methyl Alcohol 200 ppm; 262 mg/m3; 250 ppm STEL; 328 mg/m3 STEL; skin - potential for cutaneous absorption 200 ppm TWA; 260 mg/m3 TWA; 6000 ppm IDLH 200 ppm TWA; 260 mg/m3 TWA
OSHA Vacated PELs:
Methyl Alcohol:
Personal Protective Equipment
Eyes:
Wear appropriate protective eyeglasses or chemical safety goggles as described by OSHA's eye and face protection regulations in 29 CFR 1910.133 or European Standard EN166.
Skin:
Wear appropriate protective gloves to prevent skin exposure.
Clothing:
Wear appropriate protective clothing to prevent skin exposure.
Respirators:
Follow the OSHA respirator regulations found in 29CFR 1910.134 or European Standard EN 149. Always use a NIOSH or European Standard EN 149 approved respirator when necessary.
Top of Page
MSDS Index
9. Physical and Chemical Properties (Methanol, Methyl Alcohol)
Appearance: Colorless liquid
Odor: Slight alcohol-like
Solubility: miscible
Density: 0.7910 g/cm3
pH: Not available
% Volatiles by volume @ 21C (70F): Not available
Boiling Point: 64.7 deg C @ 760.00mm Hg
Melting Point: -98 deg C
Vapor Density (Air=1): 1.1
Vapor Pressure (mm Hg): 128 mm Hg @20 deg C
Evaporation Rate (Ether=1): 5.2
Viscosity: 0.55 cP 20.00
Molecular Formula: CH4O
Molecular Weight: 32.04
Top of Page
MSDS Index
10. Stability and Reactivity
Chemical Stability:
Stable under normal temperatures and pressures.
Conditions to Avoid:
High temperatures, incompatible materials, ignition sources.]
Incompatibilities with Other Materials:
Acids (mineral, non-oxidizing, e.g. hydrochloric acid, hydrofluoric acid, muriatic acid, phosphoric acid), acids (mineral, oxidizing, e.g. chromic acid, hypochlorous acid, nitric acid, sulfuric acid), acids (organic, e.g. acetic acid, benzoic acid, formic acid, methanoic acid, oxalic acid), azo, diazo, and hydrazines (e.g. dimethyl hydrazine, hydrazine, methyl hydrazine), isocyanates (e.g. methyl isocyanate), metals (alkali and alkaline, e.g. cesium, potassium, sodium), nitrides (e.g. potassium nitride, sodium nitride), peroxides and hydroperoxides (organic, e.g. acetyl peroxide, benzoyl peroxide, butyl peroxide, methyl ethyl ketone peroxide), epoxides (e.g. butyl glycidyl ether), oxidizing agents (strong, e.g. bromine, hydrogen peroxide, nitrogen dioxide, potassium nitrate), reducing agents (strong, e.g. aluminum carbide, chlorosilane, hydrogen phosphide, lithium hydride), water reactive substances (e.g. acetic anyhdride, alkyl aluminum chloride, calcium carbide, ethyl dichlorosilane).
Hazardous Decomposition Products:
Carbon monoxide, carbon dioxide, formaldehyde.
Hazardous Polymerization: Has not been reported
Top of Page
MSDS Index
11. Toxicological Information
RTECS#:
CAS# 67-56-1: PC1400000
LD50/LC50:
CAS# 67-56-1: Inhalation, rat: LC50 =64000 ppm/4H; Oral, mouse: LD50 = 7300 mg/kg; Oral, rabbit: LD50 = 14200 mg/kg; Oral, rat: LD50 = 5628 mg/kg; Skin, rabbit: LD50 = 15800 mg/kg.
Carcinogenicity:
Methyl Alcohol -
Not listed by ACGIH, IARC, NIOSH, NTP, or OSHA.
Epidemiology:
Methanol has been shown to produce fetotoxicity in the embryo or fetus of laboratory animals. Specific developmental abnormalities include cardiovascular, musculoskeletal, and urogenital systems.
Teratogenicity:
No data available.
Reproductive Effects:
No data available.
Neurotoxicity:
No data available.
Mutagenicity:
No data available.
Other Studies:
None.
Top of Page
MSDS Index
12. Ecological Information
Ecotoxicity:
Goldfish (fresh water), 250 ppm/11H, death. Aquatic toxicity rating: TLm 96 >1000 ppm. LC50(48hr) trout 8000 mg/l LC50(24hr) brine shrimp 10000 mg/l EC50(30min) Photobacterium phophoreum 51000-320000ppm, microtox test (Kaiser, K.L.E. et al. Water Pollut. Res. J. Can. 1991, 26(3), 361-431) Bioaccummulation. Bioconcentration factor for goldenide<10 (Freitag, D. et al. Chemosphere 1985, 14, 1589-1616).
Environmental Fate:
Nitrification inhibition. IC50ammonic oxidation by Nitrosomonas 160 mg/l (exposure not specified) (Hooper,A. J.Bacteriol.1973, 115, 480). Metabolised by the marine ammonia oxidising bacterium Nitrococcus oceanus with the liberation of CO2 (Ward, B.B. Arch. Microbiol. 1987, 147(2), 126-133). Degradation studies. Under anaerobibc conditions traces of carbon monoxide were formed together with methane by activated sludge inoculum (Hickey,R.F. et al. Biotechnol.Lett.1987,9(1),63-66)
Physical/Chemical:
No information available.
Other:
None.
Top of Page
MSDS Index
13. Disposal Considerations
Dispose of in a manner consistent with federal, state, and local regulations.
RCRA D-Series Maximum Concentration of Contaminants: None listed.
RCRA D-Series Chronic Toxicity Reference Levels: None listed.
RCRA F-Series: None listed.
RCRA P-Series: None listed.
RCRA U-Series: CAS# 67-56-1: waste number U154 (Ignitable waste).
Top of Page
MSDS Index
16. Other Information
MSDS Creation Date: 7/03/1995 Revision #4 Date: 4/14/1998
The information above is believed to be accurate and represents the best
information currently available to us. However, we make no warranty of
merchantability or any other warranty, express or implied, with respect to
such information, and we assume no liability resulting from its use. Users
should make their own investigations to determine the suitability of the
information for their particular purposes. In no way shall Fisher be liable
for any claims, losses, or damages of any third party or for lost profits
or any special, indirect, incidental, consequential or exemplary
damages, howsoever arising, even if Fisher has been advised of
the possibility of such damages.
Hazard Symbols: T F
Top of Page
MSDS Index
EMERGENCY OVERVIEW
Eye:
Skin:
Ingestion:
Inhalation:
Chronic:
Top of Page
MSDS Index
Eyes:
Skin:
Ingestion:
Inhalation:
Notes to Physician:
Top of Page
MSDS Index
Upper: 31.00 vol %
Top of Page
MSDS Index
Spills/Leaks:
Top of Page
MSDS Index
Handling:
Storage:
Top of Page
MSDS Index
Exposure Limits:
Chemical Name
ACGIH
NIOSH
OSHA - Final PELs
OSHA Vacated PELs:
Methyl Alcohol:
Eyes:
Skin:
Clothing:
Respirators:
Top of Page
MSDS Index
pH: Not available
Top of Page
MSDS Index
Chemical Stability:
Top of Page
MSDS Index
RTECS#:
LD50/LC50:
Carcinogenicity:
Methyl Alcohol -
Epidemiology:
Teratogenicity:
No data available.
No data available.
Neurotoxicity:
No data available.
Mutagenicity:
No data available.
Other Studies:
None.
Top of Page
MSDS Index
Ecotoxicity:
Environmental Fate:
Physical/Chemical:
Other:
None.
Top of Page
MSDS Index
Top of Page
MSDS Index
- Регистриран на: 23 Яну 2005 01:08
- Местоположение: Chicago, US of A
Lorde, moiat suvet kum teb e da pomislish mnogo dobre kade shte slojish "kazancheto" shtoto razlee li se.... a i ako ne e dobre zapusheno ot strana na kapachkata, mi se struva ch e moje i da pochne da izvetria shtoto methanol-a do kolkoto znam (da me popravi bratoto ako gresha) e dosta volatile. mnogo burzo se izpariava i ako ne e dobre kapachkata ti se namaliava purity-to na methanola. izmisli go kade shte go slagash.
brato, ami dali shte ima znachenie prez kakvi markuchi shte minava?
brato, abe pitai tam vuv vasheto daskalo oneia pichove deto praviat methanol kolite te ot de si vzimat methanola na kva cena, i kolko e pure.....moje da ima dalavera ot kadeto te go vzimat.
тези пичове използват "Етанол" и то като основно гориво на една Импала. Етанола както и метанола са доста корозивни и не могат да се използват бензинови маркучи. Метанола прониква и надува гумените уплътнения...мисля че и обикновени инжектори не стават...
със сигурност ще мина да ги питам пичовете откъде си вземат нещата...
- LordDigital
- СупраДжия
- LordDigital
- СупраДжия
А дано да има нещо така за натравяне на душата:)PAKETA_1 написа:ще проверя и в други каталози...мондей.
Инак от СупраФорума четох във връзка със опасносите от запалване ,пише че се случва да се запали ако е 100% ,ако е 50% + Вода ,до сега нема некои дето да се запалило. Един е успел да го запали след доста опити ,ма се е получил непостоянен и слабичък пламак.
- LordDigital
- СупраДжия
Потребители разглеждащи този форум: 0 регистрирани и 91 госта
